Fuel consumption research!!
por jensenbreck » 15 Nov 2017, 08:44
A friend of mine has asked me if I can get a few figures regarding fuel consumption and different boats. Could you please list the following.
Type/make/model and length of boat
Number of engines
Make/model of engine'(s)
MPG at your usual cruising speed(please state speed)
Any info regarding actual trips and fuel used, average speed, max speed, conditions, miles covered.
Apart from a well serviced engine, a clean polished hull, good props, correct weight distribution and finding the best balance with trim to speed/rpm, etc ....................
Is there any other ways to improve the fuel efficiency of your boat, adding anything to your fuel or has anyone had there engine remapped/chipped like you can get done on your car?
I didn't find the right solution from the internet.
References:
http://www.ybw.com/forums/showthread.ph ... n-research
teaser trailer
Data de registro: 07 Nov 2017, 09:20
Quem está online
Usuários vendo este fórum:: Nenhum usuário registrado online
